Trying to deploy a Fortinet VPN config profile for macOS Sequoia and Sonoma, but the profile fails to install. If I change the Connection Type to L2TP the profile installs.
Has anyone run into this issue?
Settings:
Connection Name: VPNTunnel
Identifier: com.fortinet.forticlient.macos.vpn
Server: locahost
Provider Bundle Identifier: com.fortinet.forticlient.macos.vpn.nwextension
Provider Designated Requirement: identifier "com.fortinet.forticlient.macos.vpn.nwextension" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = AH4XFXJ7DK
@ChrisTech Jamf broke the VPN payload somewhere around 11.11 (PI122416 - using "PASSWORD" instead of "Password") . You'll need to update to Jamf Pro 11.2.1 which incorporates the fix.
