Hey all,
The help file doesn't show quite enough data here... is there a way to ask the JAMF binary what current policies are running?
I'm thinking along the lines of: sudo jamf policy -showCurrentPolicies Is there any such command?
Thanks, - D
I don't think there is a way to do it with the binary, but you can
tail the jamf.log file to get that info:
tail /var/logs/jamf.log
Steve
Sent from Somewhere
Tail /var/log/jamf.log
Thanks! :-). That's what I get for going from memory at my
age....what were we talking about?
Steve
Sent from Somewhere
That will show any policies that are currently running.
Steve
Sent from Somewhere
you can check what is currently running by running the show processlist;
mysql> show processlist; +-------------------------------------------------------------------------------------------+ | Id | User | Host | db | Command | Time | State | Info | +-------------------------------------------------------------------------------------------+ | 6 | jamfsoftware | localhost:49160 | jamfsoftware | Sleep | 278 | | NULL | | 7 | jamfsoftware | localhost:49161 | jamfsoftware | Sleep | 278 | | NULL | | 8 | jamfsoftware | localhost:49162 | jamfsoftware | Sleep | 278 | | NULL | | 9 | jamfsoftware | localhost:49163 | jamfsoftware | Sleep | 6 | | NULL | | 10 | jamfsoftware | localhost:49164 | jamfsoftware | Sleep | 278 | | NULL | | 910 | jamfsoftware | localhost:57723 | jamfsoftware | Sleep | 3 | | NULL | | 1332 | jamfsoftware | localhost:52561 | jamfsoftware | Sleep | 278 | | NULL | | 1333 | jamfsoftware | localhost:52563 | jamfsoftware | Sleep | 75 | | NULL | | 1334 | jamfsoftware | localhost:52564 | jamfsoftware | Sleep | 278 | | NULL | | 1339 | jamfsoftware | localhost:52569 | jamfsoftware | Sleep | 1 | | NULL | | 1341 | root | localhost | NULL | Query | 0 | NULL | show processlist | +-------------------------------------------------------------------------+------------------+ 11 rows in set (0.00 sec)
