Hello All,
Just doing a little digging on JAMFNation in setting up our Self Service Portal, came across a script from Andrina Kelly (below) and her 2013 JNUC Presentation. Essentially, I'm looking to add perhaps an authentication hook to ensure that end-users are "indeed" entering their updated password instead of avoiding a mistaked keystroke. Perhaps a test map to a server or something.
Any advice or resources are warmly welcome! Thank you.
!/bin/bash
Created By: Andrina Kelly, andrina.kelly@bellmedia.ca, Ext 4995
Creation Date: July 2013
Last modified: July 25th, 2013
Brief Description: Deletes the users login.keychain, and creates a new keychain
Set CocoaDialog Location
CD="/Path/to/CocoaDialog.app/Contents/MacOS/CocoaDialog"
Find out who's logged in
USER=who | grep console | awk '{print $1}'
Get the name of the users keychain - some messy sed and awk to set up the correct name for security to like
KEYCHAIN=su $USER -c "security list-keychains" | grep login | sed -e 's/"//g' | sed -e 's/// /g' | awk '{print $NF}'
Go delete the keychain in question...
su $USER -c "security delete-keychain $KEYCHAIN"
Ask the user for their login password to create a new keychain
rv=($($CD secure-standard-inputbox --title "Set New Keychain Password" --no-newline --informative-text "Enter your current login password"))
PASSWORD=${rv[1]}
Create the new login keychain
expect <<- DONE set timeout -1 spawn su $USER -c "security create-keychain login.keychain"
# Look for prompt
expect "?chain:"
# send user entered password from CocoaDialog
send "$PASSWORD
expect "?chain:"
send "$PASSWORD
expect EOF
DONE
Set the newly created login.keychain as the users default keychain
su $USER -c "security default-keychain -s login.keychain"
