Hello,
I'm looking for the best way to keep the SelfService Dock item on the Dock; I currently have a policy (once per computer) that will put the icon on the Dock, but it's not the best solution- there could be multiple users, and a once per user policy won't work either. Is there a better way to make sure that a dock item for SelfService is created for every user, on every computer, at least once? Thanks.
Vincent
Try setting the Trigger to Login and Frequency to Ongoing.
I use docutil with the no restarts flag. On 10.8 because the funkiness of dock restarting I have a script to add it at logout.
