Hi
Pretty new around here,
SCCM guys asked me prior to installation if Microsoft had certified use of SCCM plug-in.
If anyone knows it will be very helpful.
Thanks,
G
Page 1 / 1
Hi -
While there is no specific certification, we are a partner of the System Center Alliance.
Our solution uses the SCCM 2012 SDK to send devices to SCCM, and does not access the SQL Database directly. If there are more specific questions your SCCM team has, please reach out to your JAMF buddy or account manager and they can connect you with folks who can go into more details.
Doug
