Hi all,
Just tried to use the jamf binary "fixDocks" verb to remove question marks for apps that don't exist in a particular set of machines. It doesn't appear to work.
Anybody using this with success? Is there a trick to it?
http://jamfsoftware.com/kb/article.php?id=021
In testing it does fix part of the Dock the dock removing questions marks for missing files and folders, but does not appear to do anything to remove broken links to nonexistent apps. Are we just missing
something?
TIA,
Matt Corippo
Lindamood-Bell Learning Processes
I.T. Dept.
My understanding is this only repairs, but does not remove broken links.
