Casper Netboot Automator Action for 10.8 NBIs?
  • March 25, 2013
  • 4 replies
  • 11 views
I am not able to get this to work for 10.8 NBIs.....is there a new version of this being release for ML or is there a way to get it to work with a ML so that it will automatically run Casper Imaging when netbooting? Thanks in advance
jhbush
Forum|alt.badge.img+27
  • March 25, 2013
I believe this hasn't worked for some time. I just make my own NetBoot disk where I have ROOT enabled and set it to auto-login and launch Casper Imaging. I have another local admin account on there as well in case I need to run something like Disk Warrior.
Chris_Hafner
  • March 26, 2013
Ditto... You can even configure a number of things in the root user that may be useful for your environment. For example, During our primary mass imaging (I work in the edu sector) I run a very simple nbi that only logs into root, launches casper imaging, and the the prestage. However, during the academic year I've got the .nbi loaded up with various diagnostic tools. I just find it nice to have the option and it's certainly not any more complicated than using the automator script.
  • March 27, 2013
you can add the net lauchpad from jamf into it as well,
Hey @krdell
Thanks for starting the discussion! The Casper Netboot Automator Action will work for 10.6 and earlier. For 10.7 and later, I would recommend using the steps in this KB article:
https://jamfnation.jamfsoftware.com/article.html?id=307
