Hi Sherry,
Did you ever get a response to this? I'm looking to do the same thing but can't find a way other than Manually. This seems cumbersome at best.
Thanks,
Adam
By restrict, what do you mean exactly? Would a simple kill process on the email applications do the trick, for example?
I think you're better off with blocking this at the firewall.
This was actually for iPads and not OS X machines.
Unfortunately, I'm trying to manage a global workforce with iPads deployed everywhere. On some of them, we wanted to "lock" the email account to just our corporate account. Thoughts on how to do this?
Firewall would work, only for internally used iPads though.
Speak to Apple about it. The sad fact is, not everything you can set manually on an iOS device can be pushed via an MDM solution, and this lack of functionality is squarely on Apple's shoulders. JAMF or any other MDM vendor can't make something happen that simply isn't possible to do OTA. Until Apple adds it in, you will need to do workarounds like firewall settings and such.
Thanks mm2270. That is what I figured but it was the answer I didn't want to hear :)
Over the past 12 months, has anyone find a way to remove the ability to create personal mailboxes on managed machines?
I'm looking to be able to do this also...we have students email accounts and we want to block personal accounts
