We have an instance of the JSS that I am migrating from a mac mini to a new mac pro and are interested in implementing link aggregation on the mac pro server. Are there any issues that anyone has experienced or anything to be aware of if link aggregation is enabled on a server that will be housing a JSS instance?
http://support.apple.com/kb/PH14045
Shouldn't be any issues at all just uses x2 Ethernet ports and combines as a virtual link and uses x1 IP address for increased bandwidth allocation. Only thing worth checking is if Casper suite supports this at the Physical layer and Transport layer im guessing.
Cheers.
