Help?
My live server will not image,
All the packages were taken off the test server which works fine, both are 6.01 versions and setup alike
The test server works fine but the live doesnt, the Live server just zips through all the packages without installing any, it doesnt run any scripts or any block copy,
below is the log on the live server
Storing SSH Account on JSS... Preparing installation... Initializing Imaging Process... Mounting afp://lamis-013.ntds.uclan.ac.uk/CasperShare... Running Partition... Result of running Partition was: Installing System.dmg... Error: The file System.dmg does not exist. Installing Audacity.dmg... Error: The file System.dmg does not exist. Installing Audio.dmg... Error: The file System.dmg does not exist. Installing ChangePassword.dmg... Error: The file System.dmg does not exist. Installing Citrix 10.00.600.dmg... Error: The file System.dmg does not exist. Installing Colour.dmg... Error: The file System.dmg does not exist. Installing DesktopPic 2.0.dmg... Error: The file System.dmg does not exist. Installing Epson Scanner V500.dmg... Error: The file System.dmg does not exist. Installing Flip4Mac.dmg... Error: The file System.dmg does not exist. Installing GroupWise 7.dmg... Error: The file System.dmg does not exist. Installing Growler 1.1.2.dmg... Error: The file System.dmg does not exist. Installing HewlettPackardPrinterDrivers.pkg... Error: The file System.dmg does not exist. Installing Hooks.dmg... Error: The file System.dmg does not exist. Installing HPScanJet2400.dmg... Error: The file System.dmg does not exist. Installing iHook.dmg... Error: The file System.dmg does not exist. Installing iLife 06.dmg... Error: The file System.dmg does not exist. Installing Keychain-reset.dmg... Error: The file System.dmg does not exist. Installing Launch Steup Hook.dmg... Error: The file System.dmg does not exist. Installing LIFixDocks.dmg... Error: The file System.dmg does not exist. Installing LOUSB.dmg... Error: The file System.dmg does not exist. Installing Media.dmg... Error: The file Audacity.dmg does not exist. Installing Microsoft Office 2008SP2 12.1.0.dmg... Error: The file Audacity.dmg does not exist. Installing MSN 7.0.0.dmg... Error: The file Audacity.dmg does not exist. Installing Office 2008 12.1.2 Update.mpkg... Error: The file Audacity.dmg does not exist. Installing Plaxo 3.10.636.dmg... Error: The file Audacity.dmg does not exist. Installing Resources.dmg... Error: The file Audacity.dmg does not exist. Installing Scanners.dmg... Error: The file Audacity.dmg does not exist. Installing Screensaver 2.0.dmg... Error: The file Audacity.dmg does not exist. Installing SecUpd2008-005.pkg... Error: The file Audacity.dmg does not exist. Installing Self Service.dmg... Error: The file Audacity.dmg does not exist. Installing SetupHook.dmg... Error: The file Audacity.dmg does not exist. Installing Toast Titanium 8.0.4.dmg... Error: The file Audacity.dmg does not exist. Installing UnMountVolume.dmg... Error: The file Audacity.dmg does not exist. Installing UserTemplate.dmg... Error: The file Audacity.dmg does not exist. Installing VLC 0.8.6f.dmg... Error: The file Audacity.dmg does not exist. Installing Wacom Intuos 3.dmg... Error: The file Audacity.dmg does not exist. Installing Office 2008 12.1.1 Update.mpkg... Error: The file Audacity.dmg does not exist. Setting computer name to "LIB301-51344"... Creating /private/etc/jamf.conf... Creating /usr/sbin/jamf... Creating Startup Script... Creating First Run Script... Copying ADBESTAMCS3_ESD1_WWE.dmg to FirstRun... Blessing System... Ensuring system files are hidden...
below is the log on the test server
Storing SSH Account on JSS... Preparing installation... Initializing Imaging Process... Mounting afp://172.31.8.103/CasperShare... Verifying Packages... Verifying Scripts... Running Partition... Result of running Partition was: Started partitioning on disk disk0 Creating partition map Formatting disk0s3 as MS-DOS (FAT) with name Windows Formatting disk0s2 as Mac OS Extended with name Macintosh HD
Finished partitioning on disk disk0 /dev/disk0 #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *298.1 Gi disk0 1: EFI 200.0 Mi disk0s1 2: Apple_HFS Macintosh HD 238.3 Gi disk0s2 3: Microsoft Basic Data WINDOWS 59.4 Gi disk0s3 Journaling has been enabled for volume Macintosh HD on disk0s2 Preparing disk for block copy... Performing Block Copy of Tamis-011.dmg... Cleaning up after block copy... Installing Audacity.dmg... Installing Audio.dmg... Installing Change Password 2.0.dmg... Installing Citrix 10.00.600.dmg... Installing Colour.dmg... Installing Epson Scanner V500.dmg... Installing Final Cut Studio 2.dmg... Installing Flip4Mac.dmg... Installing GroupWise 7.dmg... Installing Growler 1.1.2.dmg... Installing Hooks.dmg... Installing HPScanJet2400.dmg... Installing iHook.dmg... Installing iLife 06.dmg... Installing Keychain-reset.dmg... Installing Launch Steup Hook.dmg... Installing Live7.dmg... Installing Logic Studio 8.dmg... Installing Media.dmg... Installing Microsoft Office 2008SP2 12.1.0.dmg... Installing MSN 7.0.0.dmg... Installing Reason 4.0.dmg... Installing Scanners.dmg... Installing Screensaver 2.0.dmg... Installing Self Service.dmg... Installing SetupHook.dmg... Installing Sibelius 5.2.0.dmg... Installing Toast Titanium 8.0.4.dmg... Installing UnMountVolume.dmg... Installing UserTemplate.dmg... Installing VLC 0.8.6f.dmg... Installing Wacom Intuos 3.dmg... Setting computer name to "LIB301-51344"... Creating /private/etc/jamf.conf... Creating /usr/sbin/jamf... Creating Startup Script... Creating First Run Script... Copying ADBESTAMCS3_ESD1_WWE.dmg to FirstRun... Blessing System... Ensuring system files are hidden... Unmounting File Server...
any ideas as to whats wrong? it looks like maybe a permissions issue on the share?
regards
criss
Criss Myers
Senior Customer Support Analyst (Mac Services)
Apple Certified Technical Coordinator v10.5
LIS Business Support Team
Library 301
University of Central Lancashire
Preston PR1 2HE
Ex 5054
01772 895054
