Hi All
Has anyone had any success managing Parental Controls through casper.
I can see it generates the MCX files in /Lib/Manages Pres/ + complete.plist and I convert them and upload them to the JSS and enable them.
Issue is the prefs do not get applied to the machines.
I'm sure this can be done, but I think Parental controls need to be done in a special way.
Maybe generate some of them manually?
Regards
John
