Hey all,
Air Squirrels http://www.airsquirrels.com makers of Reflector http://www.airsquirrels.com/reflector just released version 1.6.3. With this release, they have modified how the Device ID is generated so that you can use Reflector now with iOS Configuration Profiles with iOS.
First you will need to configure or double check your Reflector version and Settings.
Next you will need the MAC address of your computer. I have not tested this yet with a Mac with multiple NICs so you might need to test before full deployment.
Finally, create a configuration profile with all the data we have about the AirPlay Name, Password, and MAC address into a configuration profile.
I'm pretty excited about this and hope that this helps some other folks out!
Kyle
