We have a guest account setup for our users to log into.
At the primary login window, there is a "Guest Account" and a "Others" option.
For some reason, after a user logs in and then logs off, the "Guest Account" option in the login window disappears and the only option that shows up is "Other"
We have a script that creates this guest account, adds a logo, and adds it to the login window options. Even after running the script, the option doesn't show up.
Anyone have any clues?
Be the first to reply!
