OK, Rachel just rocked our world...
https://yourJSSname:8443/apiResource.rest?resource=networksegments&method=POST
...of course replace "yourJSSname" with FQDN of your JSS.
Don
Don
Hey Don -
I posted about this under the feature request: https://jamfnation.jamfsoftware.com/featureRequest.html?id=235
But wanted to follow up with you as well. The JSS Subnet Importer: https://jamfnation.jamfsoftware.com/viewProduct.html?id=181 can help with uploading network segments.
There is also a KB: https://jamfnation.jamfsoftware.com/article.html?id=199 that explains how to use it.
Hey Jake
I tried using the JSS Subnet Importer following the given KB but unfortunately nothing shows up in http://myjsswebsite:8443 tho the log files says success.
We are using JSS 9.2.2 and the user is administrator with full access, not sure how do i proceed further.
Would appreciate if you can guide me how to import the IP Subnets to network segments.
Thanks in anticipation!!
Anyone know if this works with JSS 9.81 or 9.82?
I know...we can test...but wanted to check first. :)
Don
#crickets
Anyone know if this works with Jamf Pro 10.7.1, 10.9.0, and 10.10.0 (once released)?
