I'm fascinated by this information...
By creating a script, would it also be possible to setup an Extension Attribute that looks for attached Wacom tablets?
Nick Caro Senior Desktop Support Administrator
Absolutely.
I'd use system_profiler and grep out for your device. Crowbar that into some result tags and bob's your uncle.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
Jared beat me to it.
I haven't tested this out, but:
tabletExists="system_profiler | grep WACOM"
if [ $tabletExists != "" ];
then
echo "<result>Yes</result>"
echo "<result>No</result>"
The Wacom shows up as WACOM on one of my machines here. This should work.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
Amazing!
thank you!!
Clearly there is much for me to learn about Extension Attributes.
I would say that if it shows up in the output of the system profiler, yes...
Last script had an error, but this works and is tested:
if [ "$tabletExists" != "" ];
then
Steve Wood
Director of IT
I do the same thing for all of our graphics chipsets since (for some strange reason) the machine details don't display graphics cards.
chipset=system_profiler -detaillevel mini | grep Chipset | cut -d : -f 2
echo "<result>$chipset</result>"
j
Jared F. Nichols
244 Wood Street
781.981.5436
