Hey Folks,
Has anyone figured a way to disable that pesky iCloud window that pops up every time a new user logs in to the machine in Mac OS X Lion?
I am in the process of perfecting my Lion Image to deploy in the Summer Semester, and I need to iron out a few things, but this one seems to be the most annoying so far.
On a freshly imaged computer, a new user logs in for the first time and the System Preferences window pops up asking you to login to your iCloud account, and if it is closed then it never bothers that user again, but, when another user logs in to the computer, then the same issue happens.
Any help on this would be appreciated.
Regards,
Kamal
This question popped up in another thread:
https://jamfnation.jamfsoftware.com/discussion.html?id=45
A couple of solutions are available there.
And it might have been easier if I would have searched for iCloud in the discussion before writing this post :)
external image link
Hi Kamal
Another thread with a different approach.
Solution is to disable the MiniLaunch, hope this helps.
Regards
Mauricio
https://jamfnation.jamfsoftware.com/discussion.html?id=3860
