Probably not as the app is usually updated together with the JSS. You would need to download the latest version, re-brand and deploy to your clients via a Policy etc. The same applies if you are branding the Self Service login window by replacing the login.png file.
You could avoid this on the iOS side of things if you deploy Self Service as a Web Clip with a custom icon. In this case you would only need to replace the login window background .jpg and/or .png files in the JSS every time you update it.
Hope this helps.
I've just dug around a bit on this myself.
Please note my scope is just OSX computers, I do not currently manage iOS devices.
The naming of the app is as simple as changing the path in Management Settings -> Self Service.
It will show "/Applications/Self Service.app"
To change the name of the app file itself, its literally as easy as changing that path to something like
"/Applications/Self Help Tool.app"
Upon recon/check-in, the app will get renamed on the machine.
For icons, you can change it internally in the app itself (in the server's configuration files), but it will likely get overwritten by the stock app when you do a JSS upgrade.
Here are instructions provided by JAMF:
Instructions for changing logos...
What you will need:
iOQHajPxxdRwttJ3AROR
http://applehelpwriter.com/2012/12/16/make-your-own-icns-icons-for-free/
Step 1. Acquire login screen template (attached to this email as login.png) and modify to your liking using the image editing software of your choice. The file must remain named login.png
Step 2. Copy final login.png file to the following directories on the JSS:
/Library/JSS/Tomcat/webapps/ROOT/images/selfservice2/login_files
Step 3. In the JSS web app go to Settings>Computer Management Framework Settings>Self Service tab and click the “download the Self Service application here.” Link. Once the SelfService.tar.gz file is downloaded, double click it to unpack the self service application.
Step 4. Right Click on the Self Service Application and choose “Show Package Contents”. Replace the “Self Service.icns” file /Contents/Resources with the icns file you created for your logo, but make sure it is still named “Self Service.icns”
Step 5. Launch the downloaded Self Service app by double clicking the icon to verify that both your login screen and icon appear correctly.
Step 6. Package the Self Service application using composer and deploy with the JSS using a policy. Additionally you will want to disable the “Automatically Install Self Service…..” checkbox in Settings>Computer Management Framework Settings>Self Service tab to prevent the default Self Service application from being installed. In order to see the login screen, the “End-User Authentication” section under Settings>Computer Management Framework Settings>Self Service tab will need to be configured to require network user login.
Step 7. Save copies of all login.png and Self Service.icns files you created as upgrading the JSS may overwrite these files.
As far as I can tell, this method no longer works in Mavericks. If you modify any files inside an app bundle, you get an error when you launch the app. e.g. "Self Service.app is damaged and can't be opened. You should move it to the Trash."
Jump over to this discussion here on JAMF Nation:
https://jamfnation.jamfsoftware.com/discussion.html?id=10136
And then jump out to @emilykausalik][/url blog for her run down on how she did it for her employer. Pretty slick stuff:
http://www.modtitan.com
That's good info. I'm still not sure about Gatekeeper and the "app is damaged" message. The first time I dropped in my custom ICNS, it resulted in the damaged message. Then I tried again with a fresh copy of Self Service, and it worked fine.
Haven't been able to get around the Gatekeeper thing, though we never got a "damaged" message. Just that it was from a developer that wasn't recognized. We just had users right-click on the app in their Downloads folder and open it that way. Works like a charm.
I made up a wiki page on Sharepoint with screenshots on what the installation looks like, and sent all of our Mac users that guide when I sent out the enrollment invites. It stemmed off a lot of confusion. I managed to get all of our pre-existing users to enroll without having to touch any machines. It was wonderful.
I guess something to check, @fcloth, is how you made the .icns file. Did you use a converter or did you change the file extension? I used http://iconverticons.com and didn't run into any issues.
You may be able to get around the Gatekeeper thing by getting a developer certificate and signing the app with that. I've never done it myself, but I'm pretty sure that would work.
@emilykausalik & @stevewood, pretty sure you can contact your JAMF Account Manager for signed versions of the Casper Suite apps.
I guess this would contain a copy of Self Service too.
The easiest way to deal with Gatekeeper is to make sure you set the permissions properly. Gatekeeper ignores files owned by root. It doesn't matter if they have the quarantine flag, if the Gatekeeper settings are really strict, or if it is a signed package that has been modified. Just make sure all applications you package up are owned by root:admin, and add the ability to write to 'admin' users (otherwise you'll run into issues updating applications, like Firefox, unless you always use Casper to do the update).
sudo chown -R root:admin '/Applications/Self Service.app'
sudo chmod -R a+rX,g+w '/Applications/Self Service.app'
@Josh_S Very good to know! Thanks for the info.
