I must be doing something wrong or there is a bug.
I am running JSS 9.11
I have built stand-alone MBP stations which are not enrolled in the JSS.
I have renamed Macintosh HD to something unique.
I have installed the CasperSuite and replicated the share to a local folder.
When I launch Casper Imaging, I:
1) setup my Target Disk Mode session
2) choose my config
3) tell it to erase connect drive
4) click Start
5) connect a used MBA via Thunderbolt.
The process works as expected on the attached MBA.
It erases it, applies the OS and packages and reboots. The attached MBA is as expected and I move on and connect another MBA to be re-imaged for re-deployment.
However - the host machine is running the packages too behind the scenes...
I discovered this because of the bug with Thunderbolt imaging, where a connected drive won't mount and you have to reboot the Host. Upon reboot, the packages are then running and hose my machine.
It is not fully erasing it though. Now the Host machine is enrolled and JSS logs show it did run the whole config just as I did on the attached MBA....
I have an open ticket with Support, and they have heard of this happening with one other client and are working on it.
Anyone else have a say on why this is doing this?
