Hi all !
I'm having a software update issue with 10.6.6 (delta)
On all computers, on logout, once a week :
1) Software update policy starts
2) It displays the correct message : softwareUpdateMessage.sh
3) It starts the softwareupdate process
4) SWUP extracts the package
5) SWUP begin patching the system
Then nothing. No error message, the softwareUpdateMessage stays on, the compter doesn't reboot, and the 10.6.6 never gets installed.
Here's some logs :
Wed Jan 19 17:53:49 esl-marco jamf[41900]: Checking for policies triggered by "logout" for user "esl-marco"...
Wed Jan 19 17:53:50 esl-marco jamf[41900]: Executing Policy Update Apple Software...
Wed Jan 19 17:53:50 esl-marco jamf[41900]: Running Script softwareUpdateMessage.sh...
Wed Jan 19 17:53:50 esl-marco jamf[41900]: Installing all available Software Updates...
Wed Jan 19 18:00:49 esl-marco jamf[42829]: Checking for policies triggered by "every15"...
Jan 19 17:54:35 esl-marco Software Update[41975]: JS: 10.6.5
Jan 19 17:54:41: --- last message repeated 7 times ---
Jan 19 17:54:41 esl-marco Software Update[41975]: Folder Manager is being asked to create a folder (flnt) while running as uid 0
Jan 19 17:54:41 esl-marco Software Update[41975]: PackageKit: ----- Begin install -----
Jan 19 17:54:41 esl-marco Software Update[41975]: PackageKit: request=PKInstallRequest <2 packages, destination=/>
Jan 19 17:54:41 esl-marco Software Update[41975]: PackageKit: packages=( "PKJaguarPackage <file://localhost/Library/Updates/041-0012/RemoteDesktopClient.pkg>",
n "PKLeopardPackage <file://localhost/Library/Updates/zzz061-9625/MacOSXUpd10.6.6Patch.pkg>" )
Jan 19 17:54:45 esl-marco Software Update[41975]: PackageKit: Extracting /Library/Updates/041-0012/RemoteDesktopClient.pkg/Contents/Archive.pax.gz (destination=/var/
folders/zz/zzzivhrRnAmviuee++++/Cleanup At Startup/PKInstallSandbox-tmp/Root, uid=0)
Jan 19 17:54:47 esl-marco Software Update[41975]: PackageKit: Extracting /Library/Updates/zzz061-9625/MacOSXUpd10.6.6Patch.pkg (destination=/var/folders/zz/zzzivhrRn
Amviuee
Jan 19 17:54:58 esl-marco Software Update[41975]: PackageKit: Patching System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Jan 20 09:10:40 esl-marco Software Update[4638]: JS: 10.6.5
Jan 20 09:10:43 esl-marco Software Update[4638]: JS: Firmware is up to date.
Jan 20 09:10:43: --- last message repeated 1 time ---
- If I do the softwareupdate manually, it works fine.
- If I do the softwareupdate manually, and when restarting the policy gets executed, I have the same problem
Any idea ? Have you experienced the same issue ?
Thanks !
Francois
Francois Tiffreau | IT Operations Manager
ESL Education SA
Head office – Switzerland
Grand-Rue 50, CH-1820 Montreux
t +41 21 962 88 80 | f +41 21 962 88 81
skype esl.francois
http://www.esl-education.org
Please consider the environment before printing this e-mail
This e-mail message may contain certain confidential and privileged material for the sole use of the intended recipient. Any review, use or distribution by others is prohibited. If you are not the intended recipient, please contact the sender and destroy or delete all copies.
![external image link](attachments/39eb24d93de14b9da608e780944e474e)
![external image link](attachments/d33411df21ba4c7083ce0968acfec0c9)
Yes, experiencing the same issue, but I haven't had the time to look into it too deeply as not all of our machines are scheduled for the 10.6.6 update. The ones that are, though, are having this problem.
- Jeff
I just sent a message to support about this, I have actually been having
this issue since 10.6.4. It seems completely random and doesn't matter if I
am using my internal SUS or Apple's. I have had it hang on iTunes, Remote
Desktop Client Update, iWork, and 10.6.4-10.6.6. When I image or reimage a
computer, my base image is 10.6.4, and it has no problems installing all of
the updates using my postimage script on the first boot. Doesn't make any
sense...
Alan Benedict
Macintosh Technician
The Integer Group
O: 515-247-2738
C: 515-770-8234
http://www.integer.com
![external image link](attachments/704b95683df542f08b43dfc2d71c3bc1)
![external image link](attachments/7e76f9b856a24dbda1f3e9c47e0fe674)
