I'd like to block out most system preferences from pretty much everyone, but I'd like to keep stuff like Wacom and Symantec pref panes accessible. I do not see a way to do this with Casper config profiles. I was under the impression that if the pref pane is installed on the management server you could select it as a restricted pane or not.
Anyone know a way around this?
I want to block the iCloud, mail/contacts/calendars, sharing, and language panes. Everything else can stay because they either require admin rights or I don't care what they get set to.
https://jamfnation.jamfsoftware.com/article.html?id=204
Thanks bajones! WOrked like a charm
