I am trying to set up imaging for machines. In general, we have no issues with JSS or JDS in terms of uploading, downloading, or replicating packages. JDS and JSS are both on Centos. The Netboot server is on a Mac. I created the computer image and uploaded it and made a netboot set with JAMF netboot set tool.
When I netboot and attempt to image a machine, the imaging fails with the error:
"There was an error mounting the file server https://ourjds.example.com/CasperShareDAV/"
I tried switching the netboot set to HTTPS, instead of NFS, but the issue persists. And I also turned off iptables on the JDS to eliminate firewall issues. I can reach https://ourjds.example.com/CasperShareDAV" via browser, but it rejects any JDS or JSS credentials I use. I'm not sure if that is a red herring or indicative of the problem.
Any suggestions on what to try next?
