Hello,
If you are familiar with NeoOffice you know that they release patches often. They come in a nice PKG format that are easy to deploy with ARD or policies.
Here my problem: I can't seem to get the patches to install correctly while the computer is imaging. I have it setup to first install a NeoOffice 2.2.5 Patch 0 DMG Package that I created with Composer. Then it installs the Patch 6 that I downloaded right from the NeoOffice website. After the computer reboots, I log in, launch NeoOffice and it comes up as Patch 0. The Patch 6 never installs correctly, but there are no errors.
The Patch 6 does install correctly if I set it up to install upon login, as a policy.
Has anyone come across this problem?
Thanks
Brad Rellinger
Technology Specialist
Anthony Wayne Schools K-12
aw_aca_bre at nwoca.org
Be the first to reply!
