The subject pretty much says it all. If I make changes to a configuration profile that is already installed on the devices and then click the "distribute to all" button, nothing happens on the devices, however a new item appears in the queue for each device with the status "pending".
If I manually select each device in the JSS and send a "blank push", then the queue immediately empties and the changes apply.
This doesn't affect new profiles, which seem to apply properly.
Have you gotten anywhere with this issue? We seem to be having similar problems.
Hi Itss
Please refer to my post in the following discussion;
https://jamfnation.jamfsoftware.com/discussion.html?id=10113
Both your JSS and mobile devices require a persistent connection to APNS to receive and execute commands successfully.
Regards
Sean
