First time creating discussion, please be gentle...
Thank you for the support in advance.
I am trying to adjust the search criteria to search through a range of numbers, our inventory is numbered and it would be great to create a smart group with a selected range, instead of having to select each and every instance. I want it to, lets say, start with #1 - #15, #22 - #43 and so on. I am not exactly how to do this and if this is even possible. Any advice?
Be the first to reply!
