Managing about 40 iMacs in a college lab environment.
I have found that booting off a USB stick is incredibly slow, and I've never had very good results with NetBoot. So I thought I'd create a Casper Imaging partition on the internal HD of my lab Macs and re-image from there.
I stuck this script in a policy with a restart at the end, and it works.
Don't try this if security is a huge concern for you. In our case, hiding the imaging partition from the Finder, plus the fact that you still need to enter the JSS password, should be adequate, at least during the summer when nobody's here. (And if someone re-imaged a computer by mistake, it wouldn't be that big a deal -- all user data is on the server anyway).
step 1: create a Casper Imaging boot volume in the usual way
step 2: make a read-only compressed .dmg from it
step 3: upload the .dmg to Packages directory of your Casper share (or wherever)
step 4: run this script via policy; force restart after the script
#repair the disk
diskutil repairvolume /
# create mount point
mkdir /Volumes/tmpImaging
#mount casper share point
mount_smbfs //user:password@my.casper.server/sharepoint /Volumes/tmpImaging/
#copy source dmg of the customized Imaging partition to local HD
cp -f /Volumes/tmpImaging/Packages/imaging_partition.dmg /Users/Shared/
#unmount casper share point
umount /Volumes/tmpImaging
#shrink primary HFS+ partition by 5% and create casper_imaging partition with minimum size 20G
diskutil resizeVolume disk0s2 95% HFS+ casper_imaging 20G
#mount the source dmg
hdiutil attach /Users/Shared/imaging_partition.dmg
#copy source dmg to the imaging partition
ditto /Volumes/imaging_partition/ /Volumes/casper_imaging/
#hide the imaging partition
chflags hidden "/Volumes/casper_imaging"
#rename the primary partition "Macintosh HD" (otherwise imaging will fail, because that's what's in the Autorun data) - YMMV
diskutil rename disk0s2 "Macintosh HD"
#set imaging partition as boot volume for next restart
bless -mount /Volumes/casper_imaging -setBoot -nextonly
