Happy Holidays Everyone! I am setting up the netsus 4.0 and I am getting the following error:
The certificate for this server is invalid. You might be connecting to a server that is pretending to be "my server" which could put your confidential information at risk.
has anyone else experienced this?
All the best!
~/k
This is typical, it uses a self signed cert when you set it up and there's nothing wrong with that. Just hit connect anyways (or whatever it is for your respective browser).
This is only for the web interface, so I wouldn't worry about it. If it's a problem because of policy I believe there is a way to add an actual signed cert. But it really doesn't matter since clients connect over http anyways.
I get the error when I am in the app store trying to do updates.
Try connecting over http instead of https.
Change the SUS host name in the preferences of the NetSUS.
