I created a Finder configuration profile that has the Shut Down and Restart Finder option disabled (Under Apple Menu). Exported it and installed it on a 10.11.2 mac (the mac should not be enrolled.)
Profile installs, and everything look normal.
But the setting never stick. Anyone experienced this? bug? I believe I created same profile with Apple Profile Manager earlier this year, same thing happened.
Be the first to reply!
