Hi:
Having an issue where it seems that Yosemite client cannot copy large files over SMB to a Windows 2012 share, though Mavericks clients are fine. Some similar posts here:
http://www.insanelymac.com/forum/topic/301961-writing-to-remote-refs-share-4gb/
http://forums.macrumors.com/showthread.php?t=1845504
The copy will not start at all if the file is just over 4GB (the threshold is around about 4.35GB). The error is "The item can't be copied because it is too large for the volume's format". It will copy fine if the file is less than 4GB (or any size on Mavericks). Anyone else seeing this issue?
We are having the same issue. Any help would be greatly appreciated.
