I had an old CS4 package that was improperly removed from the JSS. I think it was manually deleted from the master CasperShare directory, and then later from CasperAdmin- or something stupid like that.
Anyway, the package absolutely is not on the JSS, not present in Casper Admin; but every time I sync a DP, I get: ERROR: Cannot copy AdobeCS4DS.dmg (AdobeCS4DS.dmg) because it does not exist on the master distribution point.
Any ideas how I can eradicate this ghost for good?
Bit of a hacky way of doing it, but I had this issue once, so I just created a dummy dmg with the same name, dragged into Casper Admin, did a sync through my distribution points (which worked), then deleted the dmg in Casper Admin, synced again, and voila.
Actually, that's brilliant, and looks like it will work.
Thanks,
