Hi all,
I'm fairly new to the Casper suite.
I have a script that removes alle user homefolders that contain a number in their names at logout and generates a logfile.
I have set it by a policy with (Trigger logout). It does execute fine every checkin when (Execution Frequency) is set to ongoing. But that's not what I want, I want it triggered by a user logout. My other options are (Once per computer or a specific date)
When I change Execution Frequency to anything from ongoing it stops working, does not execute when users logout.
At (Computer management - Check-in) I have enabled: (Create login/logout hooks) and (Check for policies triggered by login or logout)
Please help,.....
Why do you not want it ongoing? Ongoing means that it will continue to run at your trigger. So a policy set to at Logout and ongoing, will run every time a logout happens. Isn't that what you want?
