Just wanted to check and see if anyone else has see this issue. Currently I have created a new Profile in JAMF 8.7 that distribute SCEP settings to the clients. I can successfully request a certificates but only a few times in a row then it stops working for a long time. After several tries the client will pickup a new certificate with no issues. I have the root cert and issuing cert on the end device and fully trusted but it continues to fail after a bit. Anyone seen anything like this and have you been able to fix the issue?
Jamf SCEP profile not consistently distributing certificates.
