I am based in Sydney, Australia.
Hi
Do you mean if someone has an externally facing and accessible JSS? The best thing to do is to contact JAMF and they can arrange a demo for you.
This something that Computers Now, JAMF's reseller in Australia should be able to help you with - email casper@compnow.com.au
If you get hooked up with a JAMF demo, they can set up a JSS in the cloud for you to check out. They may be able to pre-populate it with a demo database. Talk to your JAMF rep.
@cgerke
I'll be in Sydney all next week for CeBIT and the Comp Now Road Show. If you are avaliable stop by the Comp Now booth or the Road Show event at the Rydges World Square. I'll be sure to get you what you are looking for.
Details: http://www.caspersuite.com.au/
@cgerke
I'm Based in Sydney Australia too. Compnow are great resellers of the software and certification, they also provide the Jumpstarts, i use them currently. the guys there are pretty good at what they do.
but if you need any questions from a fellow local, let me know!
Cheers
-Rusty
