I thought I had this figured out.
I want to call a policy after another policy has run. In files and Processes I put
sudo /usr/local/bin/jamf policy -event -id 603
I have confirmed that 603 is indeed the policy# but when I run the policy I get:
Running command sudo /usr/local/bin/jamf policy -trigger -id 603...
Result of command:
Checking for policy ID 603...
No policies were found for the ID 603.
What am I doing wrong?
ID 603 Name ....................................... Install Alertus 2.9.30.1700 Enabled true
