Has anyone been able to succesfully block the OneDrive for Business app?
I've tried numerous combinations of file name / process name and can't for the life of me get it to work.
app is: OneDrive for Business.app
Process is: "OneDrive for Business"
ideas?
try OneDrive for Business* (with the asterisk) and check the box to Restrict exact process, and Kill Process..
Then on test machine.. go into terminal and run sudo jamf manage.. Then try and see..
That did it. Thank you sir. Probably the one combo I didn't try.
You're Welcome.. :)
