Hello,
I have a topic regarding Casper maintenance options and could use the community’s assistance.
Recently at Extensis we’ve encountered customers who have chosen to run the “Flush (User and System) Caches” on their machines at startup but are not forcing the systems to restart after the process. This Casper maintenance task is clearly causing instability in the OS and causing all sorts of font related issues.
Not having a Casper installation at Extensis we had to play detective and rely on our review of Universal Type Client logs against the customer’s Casper logs to realize the cache flushing was causing their system instability.
Normally (as a best practice) I would expect that the OS would be restarted after this type of maintenance task but I’m not really sure what the best practice should be since Casper allows cache flushing without a system reboot.
So my questions are as follows:
- Does anyone run the Flushing Caches option in their environment?
- If so should caches be flushed on a regular basis and how often?
- Is employing a scripted OS restart the best practice or should the Casper product enforce this automatically when system caches are deleted during startup?
Thanks in advance for your feedback.
Cheers,
Chris Meyer
Sr. Product Manager, Font Management Solutions
2012 Celartem, Inc. dba Extensis. All rights reserved.
