Just wondered anyone uses Adobe Client ID in Enterprise? I mean users to allow access using their enterprise email as an Adobe Cloud ID. This allows users to install a copy to their home computer etc...
we're just now beginning the talks with Adobe, I'm pretty sure this will come up soon enough for us.
Yep, we are. Our attitude about it is that the Cloud team access is like a perk. Though honestly, I'm not sure what (if anything) happens when their license is revoked. I'm guessing they can't run updates or install other software? But we were kind of backed into a corner into it by our reseller so we didn't have much of a choice.
I believe that CC installations will continue to work for 30 days after the last valid login.
