Hello,
I've been using the method on the Der Flounder blog to capture the GarageBand 10.0.2 package from an AppStore install. However, every time I install using this captured file I get the error that GarageBand is damaged. Are people now needing some other method for getting and distributing the latest GarageBand app? I've tried capturing the GarageBand app on a few different computers. The resulting file has always been the same size and checksum: 985.9 MB as shown in Finder.
Re-reading the many posts on this topic I finally completely read the following post:
https://jamfnation.jamfsoftware.com/discussion.html?id=8729#responseChild64826
After doing that after the GarageBand install, it loaded properly. I have not needed to do this on any other app using the AppStore method to get the install package. First time for everything I guess.
