I have a computer lab setup where I have a partition where students can save documents that will survive the nightly re-imaging. However, by default the partition has rw permissions for root only. How is the preferred way, or where is the best place, to set the permissions for that partition?
Thanks,
-Baker
Baker Franke
Computer Science Dept.
University of Chicago Laboratory Schools
773.702.5419
As part of your nightly re-imaging, can you add a final script that does a chmod on that partition to a mask of 777? A single line of code could solve that.
j
Jared F. Nichols
Desktop Engineer, Infrastructure & Operations
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
Sounds like a job for ACLs
Well, that's what I was going to do. I was just wondering if there was a different "casper-approved" way to do this.
Thanks,
-Baker
Baker Franke
773.702.5419
