Hi
I'm looking at maybe using Jamf Connect, with our Okta environment.
So if i understand this correctly, during a login process for a user, they would turn their MacBook on, already be connected to their wifi, and just login using their Okta creds.
Our Okta environment is configured to only allow login from trusted IP's (e.g our VPN)
How can our users login using Jamf Connect, if the VPN hasn't been activated/enabled yet (e.g before the macbook login process has occured)
Thanks
Be the first to reply!
