Today we released Jamf Connect 2.23.0. This release includes the following changes and improvements:
You can download all Jamf Connect logs from the past 30 minutes using the jamfconnect logs command in Terminal. For additional information about the command, use jamfconnect help logs.
To access new versions of Jamf Connect, log in to Jamf Account with your Jamf ID. The latest version is located in the Products section under Jamf Connect.
Product Documentation
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
Thank you!
The Jamf Connect team
Be the first to reply!
