I am concerned.
I only recently discovered that if someone changes their password outside of Jamf that they need to log in with their old password and then sync the new password.
The catch is that we have a Windows and Mac environment and depending on which class a student is in, they could be using one for one class and the other for the next. This means they could be changing their password on either machine or on their phones and not directly through Jamf.
We use Entra (previously Azure) and I don't know if there is some better way to sync or some way to assist students who may get stuck and I'm a little worried.
Does anyone have any help or advice? I am happy to explain better if this wasn't good.
Be the first to reply!
