Good Morning, we have been testing out Jamf Connect Login with Azure AD and it has been working without issue. Now it suddenly stopped bringing up our users login information. It shows the Windows login box, but its just a white box and doesn't allow us to do anything or make any changes. I was wondering if anyone else has seen this issue and been able to fix it. I deployed Jamf Connect on new system and had the exact same issue. There have been no major changes to the system or the network.
Yep,
Existing fault https://www.jamf.com/jamf-nation/discussions/31538/jamf-connect-login-for-azure-no-username-or-password-field
This is fixed in the latest release of Jamf Connect.
