Today we released Jamf Connect 2.3.2 for general availability; this release includes the below details.
Key Feature Content
New Menu Bar App Preference for Network Checks: You can now use the Perform Network Checks on Network Changes (checkOnNetworkChange) setting to determine whether Jamf Connect performs a network check when a computer's network status changes.
Key Technical Content
Change to Admin Roles Setting in Jamf Connect Configuration: Jamf Connect Configuration now only configures the Admin Roles (OIDCAdmin) setting as an array of strings.
Bug Fixes
• [PI-009217] Fixed an issue that prevented the NameID attribute in email format from correctly being used as the user's account name when Jamf Connect was used to create users from Okta via Jamf Pro's Enrollment Customization settings.
• [PI-008734] Fixed an issue that caused password policy information detected from Active Directory from displaying correctly in Jamf Connect's Password Change and New Password windows.
• [PI-009494] Fixed an issue that prevented the Formatted ID Token Path (OIDCIDTokenPath) and Raw ID Token Path (OIDCIDTokenPathRaw) settings from storing a user's ID token at the configured file path.
• [PI-009516] Fixed an account migration issue that prevented Jamf Connect from searching for an existing local account that matches a custom short name configured with the Custom Short Name (OIDCShortName) setting.
• [PI-009613] Fixed an issue that prevented VoiceOver from reading text fields in the Jamf Connect login window.
Product Documentation
For more information, including Release Notes, please see the Jamf Connect Administrator Guide.
Thank you!
The Jamf Connect team
@jen.kaplan Thanks for the update!
I deployed JAMF connect in March using Google Apps - Gmail as the ldp partner. Which broke our zero-touch enrollment workflow. At first boot, users get taken to the ladmin login window and must restart for the JAMF connect login window to appear.
@sean.rabbitt Script seems to be the best tool to fix this right now.
Can the Jamf Connect team fix this issue at its root level and release it in a new update of the product? Thanks, ~ B
@bcrocket, in your deployment of Jamf Connect, did you reset the autchanger to JamfConnect?
2.3.2 seems to have broken our notify-script. It just doesnt seem to run with 2.3.2. Still works fine with 2.3.1. Downgraded and troubleshooting...
@abnaau are you using a config profile for the authchanger settings by chance? If so there is a bug in 2.3.2 that breaks using authchanger using a profile. PI-009673
Try running authchanger from the command line or a script with the -Notify argument.
Yup, that must be the issue.
