I would like to change the default background image and logo from the login interface of Jamf Connect, but was no able to find much information. I can see these specific parameters here: https://docs.jamf.com/jamf-connect/1.19.2/administrator-guide/Configuring_Jamf_Connect_Login_with_Microsoft_Azure_AD.html, but I don't know how to upload the respective images on the local path on the Macs
Page 1 / 1
Just drag and drop your custom images into the left column in Composer from wherever you want to store them (e.g /usr/local/images/mycustombackground.png). Fix the permissions on the files and export the PKG and deploy it using a policy. Then as long as the paths in the parameters match up to where you have deployed them to, you should see the custom imagery.
