In Sub-Location the Update Button for Devices is missing. The functionality (if enabled for the users role) is accessible via the direct link. https://*.jamfcloud.com/devices/updates.html
The link should be available in the sidebar if it is enabled.
problem solved. the setting wasn't set for the location in settings->general "Allow Jamf school to check for OS updates"
