Does anyone have a step-by-step instruction list for creating a Lion Installer package? I tried adding InstallESD.dmg via CasperAdmin and checking the box that it is an OS Installer. Casper verifies the package successfully, but then says it is not an OS installer.
I'm new to this aspect of Casper and the 8.21 docs are sparse on step-by-step instructions for how to create an OS installer. I see that in most cases you need to install the OS by hand on a given platform, configure it for your environment, then use the Casper Imaging tool to snapshop that system and make an installer package.
In the Casper List I have read that people were able to simply use InstallESD.dmg inside the Install Mac OS X Lion.app/Contents/SharedResources folder but I can't seem to get it to work for me. Perhaps I've missed some steps or don't have a firm enough grasp of what to expect. Ideally I would like to set this up as a Self-Service package until I have tested it and feel comfortable with what it will do.
Thanks in advance,
Walter
Walter Rowe, System Hosting
Enterprise Systems / OISM
walter.rowe at nist.gov<mailto:walter.rowe at nist.gov>
301-975-2885
