Our machines have the Guest Account turned off... and I want to turn them all on.
Does anyone have the command or a tip for enabling Guest account via command line or policy?
Peter
Peter Gawlocki
Infrastructure/Desktop Support, Tier 2
Cell Signaling Technology
3 Trask Lane
Danvers MA 01923
pgawlocki at cellsignal.net
You want a local user account on all machines, or like a domain account? also, what version of OS X are you guys running? There are many ways to do this, just depends on exactly what you want to do
If u have a mac od u can do it there
Criss
Peter,
If you are running Casper 7.1 you can do this as a managed preference..
I've tried this and it works very slick, and can be scoped the same as
any other policy.
Under the Managed Prefs Templates, it is the item "Disable Guest
Account" (just set to False) within the com.apple.MCX area.
Hope that helps
Jason Weber
Technology Support Cluster Specialist
Certified Casper Administrator
Independent School District 196
jason.weber at district196.org
