Hi all,
Is anyone else deploying scanner drivers after the initial install? I just
had a user request the drivers/software for the HP ScanJet 8270, and the
installer closes all open applications and restarts after it's done, so I
can't capture the installation with Composer at all.
I'm also not sure what files are installed, aside from the stuff in
Applications, Application Support, and Preferences. So I can't go grab all
the files individually and drag them into Composer after the fact.
Anyone else had success? Something I'm overlooking?
