You could put the package in a .dmg that places the .pkg in /tmp, then use a script to run (set as AFTER) as the current user to install the pkg. Something like this:
currentuser=`stat -f "%Su" /dev/console`
sudo -u $currentuser installer -pkg /tmp/Polycomblahblah.pkg -allowUntrusted -target /
You may need to experiment with it to make sure that particular package will run like this.
Running anything as a user instead of root is a VFAQ here. In your case, there's a couple ways to do it. If I had this task, I would do it this way.
1- create a script to run the installer and save it as /usr/local/anniwayy/installPolycom.sh
#run the installer
installer -pkg /usr/local/anniwayy/PolycomRPD.pkg -target /
#remove the launchAgent so it won't run again
rm -f /Library/LaunchAgents/edu.anniwayy.installPolycom.plist
#remove the script to clean up
rm -rf /usr/local/anniwayy/PolycomRPD.pkg
#remove the package
rm -f /usr/local/anniwayy/installPolycom.sh
2- create a LaunchAGENT to run the installer in /Library/LaunchAgents/edu.anniwayy.installPolycom.plist
<plist version="1.0">
<dict>
<key>Label</key>
<string>edu.yourschool.anniwayy</string>
<key>ProgramArguments</key>
<array>
<string>/usr/local/anniwayy/installPolycom.sh</string>
</array>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
3- Set the permissions right.
chmod +x /usr/local/anniwayy/installPolycom.sh
chown root:wheel /Library/LaunchAgents/edu.anniwayy.installPolycom.plist
chmod 644 /Library/LaunchAgents/edu.anniwayy.installPolycom.plist
4- Put those three items into a package with composer. Then the next user that logs into the computer will have Polycomm installed.
Use outset
1.Place script in login-once/login-every folder
2.Done
Does anyone know why, no matter what package I supply (even one I created that does nothing and does not require root or admin), the installer command tells me I have to be running as root? I don't see how these instructions would work unless I am missing something here.
