What is listed for the flash plug-in for the inventotry on those units
maybe?
Craig Ernst
UW-Eau Claire
(715) 836-3639
Sent from my iPhone
Use the Advance Search of Inventory Tab, search for the plugin and
create smart groups. This .may help you
Regards,
Karthikeyan M
There is a txt file that displays the version
bash-3.2# cat /Library/Application Support/Adobe/Flash Player/Flash Player.plugin/Contents/version.txt
take that into a variable in a script with a custom trigger policy, then compare it to the version you want, if is equal or greater it exits, if not it installs custom trigger policy to install flash.
-tom
I am using Automator and I get the Flash version but I'm not sure how to pass that into a script to trigger an install if needed.
Thanks,
Nelson Miller
IT Manager
Comanche School Dist I-002
(580) 439-2913
You can just lay down a dummy package and then scope your deployment on
that. Something like
Touch /Library/Application Support/JAMF/Receipts/Flash12345.pkg
Would do it.
j
Nelson,
This is a lot easier than you would think. Let me give you an example.
create a policy that installs your desired version of flash. For example, lets say you are installing version 10.1.3 (I just made that up), and you only want it to be installed if the client has version 9 or lower. So, add it into Casper Admin and in the JSS give it a custom trigger of install_flash_10.1.3 for example.
Now, here is how you would run it in a script
# get the current version of the flash player plug in
CurrentVersionFlash=/bin/cat /Library/Application Support/Adobe/Flash Player/Flash Player.plugin/Contents/version.txt
# now check to see if it is greater than version 9
if [[ $CurrentVersionFlash -gt 9 ]]
then /bin/echo "Version is greater than 9.0, doing nothing"
else /usr/sbin/jamf policy -trigger install_flash_10.1.3
Now just set your scope and sync the distribution points and let the policy rip. You can add a dummy receipt instead of echoing it out, like touch /Library/Receipts/hasflash10.txt or whatever if you want to create a policy log of all machines that do have it as the same time. Then all you need to do in the future is add the flash installer again to the Casper Admin, and tweak one line of code to to see if it is greater than the version you want to install, and apply again.
You can contact me directly if you have any more questions, but this method is simple and I am starting to use it a lot for custom trigger policies, it really lets you customize things you want to do.
?xml version="1.0" encoding="ISO-8859-1"?>
